So, trying to test Alkalinity for the first time. Currently, my first tests are...
FC: 3
pH: 7.87 (digital test, since i can't distinguish the colors)
CYA: 50 (should be up to 65 or so with the next test)
I did the Alkalinity test twice just to make sure I'm doing it correctly, and I don't think I'm getting it right. It turns green with the second reagent (edited), then turns clear with the 3rd reagent (edited)... but I don't see a red color at all, and I don't think I see pink either. I had the pool maintenance guy use one of his Aqua Check test strips, and TA comes out at 50. I'm wondering why I can't make the TA test work. The video I watched on the TF-PRO website (linked to YouTube) didn't show the tester "wiping" the tip after each drop (even though the instructions said to do so) so I didn't wipe between drops either. Nor did I hold the bottle completely vertical (I didn't think that mattered?). I'm color blind, so maybe that's part of the reason this test isn't working for me but after 14 drops, the water still looked clear and not red. That doesn't make sense since the AquaCheck test strip seems to show 50 for TA.
It it possible I'm mistaking clear for light pink? I was looking for red since the instructions said red...
My other test levels seem okay, and the water is super clear as well.
FC: 3
