TF-100pro instructions
BrantlyJ
13
Iowa
Got my kit today and the instructions were pretty lacking. Little disappointed actually.
The only instructions included were for chlorine, calcium, TA and CYA.
I was able to identify the reagent for PH but don’t know how many drops to use. And there were 2-3 other bottles that I have no clue what they are for.
Is there a compressive set of instructions somewhere?
Newdude
10,371
NY
5. Fill the block to the top line, add 5 drops, cover and shake. Compare the color to the block by putting it on white paper or holding up to the sun. You really only need to know high and low. All 7.X values are fine for most. With your SWG your PH will probably want to remain on the higher side. Let it. Don't adjust it until it is 8, and then only adjust it a little to 7.6.
What are the #s ? Maybe they are your salt test bottles ? One is silver nitrate the other is chromate. Or r-0718 and r-0630
BrantlyJ
13
Iowa
In the kit I have R-0003 and R-0600. Loose in a bag were R-7065, R-7065,R-7064, R-7073 and R-7062.
Newdude
10,371
NY
Looks like you are missing a bunch of bottles. Email them to verify they are on back order and it isn’t just an accident. Rebecca is awesome and will do whatever she is capable of, global supply chain notwithstanding. I have seen many many updated posts here where she stepped in to make it right, even when it was UPS/FedEx/USPS fault.
Did you order all the ‘standard’ bottles, or just the test kit. Standard bottles are pool water with a known value so you can test it to practice. If you didn’t specifically order those on the side, I think you got a full kit with the wrong bottles. Or they ran out of stock the other day temporarily. Either way Rebecca is awesome. :)
Here are my instructions if you want to print them out at some point all on one sheet. 2C9FB451-0395-4708-B191-F27D2FCF6630.jpeg
BrantlyJ
13
Iowa
Here are my instructions if you want to print them out at some point all on one sheet. View attachment 358082
I ordered the test kit and intended to order the PH meter and I got the standards kit. The website was acting up that day or I just fat fingered. But I got what I ordered although I didn’t intend to order the standards.
I also wanted extra CYA reagent. Typed that into the search box and clicked add to cart in what came up. Well it was an extra bottle of CYA standard. 🤦‍♂️ Wish someone would have questioned that when fulfilling the order. It in the end I guess that’s one me.
I can’t find the TF-Pro kit in the site anymore. I also emailed that the bundles link was broken. So the website is defiantly wonky.
I do have the instruction card but the kit has 7 tests and the card shows 4, so I’ll have to watch the videos for the remainder and type those up.
mknauss
43,640
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Email [email protected] with your issues.
They are having supply chain issues and TFTestkits is a small family business that has suffered a significant loss. So things have been a bit upside down. Please provide them some patience and understanding.
