Thanks. The pool is clear. Do you mean no need to SLAM or I should SLAM?In your climate, that CYA is pretty low. You must be adding/generating a bunch of FC per day to get to 16 ppm as you are mostly likely consuming well over 5 ppm FC per day.
Raise your CYA to 70 ppm, if the pool is clear and no need to follow the SLAM Process. Target a FC of 7 ppm.
