TF-100 Test Kit
6XSBChamps
218
Longview, Tx
I just opened my TF 100 test kit (like a kid at xmas). I only took a quick look through the box but did not see any instructions. Is there anything on here that I could use as a resource for all the various tests?
6XSBChamps
218
Longview, Tx
first test out of the box and FC is 16. Does that seem right?
it took 32 drops of R 0871 to get the water clear.
I know I can pull up a thread that tells me what a good free chlorine reading is but I’m on my phone standing in my backyard right now.
Newdude
19,938
NY
It's high but should be no issue so long as you have a CYA in the SWG range. This time of year the SWG will keep overproducing each time the UV from the sun decreases with lower angle and shorter days. It's a great problem to have as you will not be going green.
Also its totally safe up to SLAM per the FC/CYA Levels, but its also a little bit off your cell life (literally like an hour) so catch it sooner than later.
Reactions: 6XSBChamps
6XSBChamps
218
Longview, Tx
Thanks. My CC was .5 and barely that, which is what I want?
Newdude
19,938
NY
Yes. The CC test may have some error or a bit of actual CCs that’s not from algae. .5 or less is good. (y)
mknauss
52,206
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
From OTO Chlorine Test - Trouble Free Pool
You can use this test to get a vague idea of extremely high TC levels. If the sample turns a particularly vivid yellow the TC level is between 5 and 15, light orange is between 10 and 20, dark orange is between 15 and 30, and brown is 30 or higher.
mknauss
52,206
Laughlin, NV
Fiberglass
In your climate, that CYA is pretty low. You must be adding/generating a bunch of FC per day to get to 16 ppm as you are mostly likely consuming well over 5 ppm FC per day.
Raise your CYA to 70 ppm, if the pool is clear and no need to follow the SLAM Process. Target a FC of 7 ppm.
