- Jun 22, 2014
- 48,209
- Fiberglass
- CircuPool RJ-45 Plus
You're on your way!Success! It has begun! FC 11, CC .5 - sock with stabilizer in front of the return!
Hopefully, but take nothing for grantid. Follow each & every step on the SLAM Process page. Now may be a good time to remove that ladder as well and inspect the tubing if possible. We've seem horrible gunk get clogged-up in those. Some folks will use pressure nozzles to flush them out, then inject chlorine into them with a syringe or turkey baster. My point is, algae is a tricky beast. Check liner folds, anywhere that algae can hide.Hopefully this will be a short slam!
You can rinse them and pour them out. Won't hurt anything. Dispose of the plastic as you normally would.what do I do with old bottles of reagents?
That's how you do it! When life interrupts the SLAM, test/adjust the FC when you get back. Maintain as best as you can. Take a pic of the water each day to monitor progress.tested chlorine at 9.5 ... added to get back to 12. Out for few hours and will test again before bed time!
That's great! The water is maintaining very well. That's a good sign.Was gone for about 4 hours, tested - FC 11.5,
