Hi,
I am new here and I am having some problems with my TF-100 kit. The paper instructions were wet when I opened it. I am not sure which chemical leaked. The inside of the chlorine only cylinder was slightly wet on the inside too. When I filled it with pool water it turned bright yellow, if that helps. I rinsed it out a bunch. The R-0870 powder was a big rock when I opened it. I smashed it up with the scooper to get it back to a powder. I don't know if that is normal or not. Anyway, it took 44 drops of R-0871 to get the water to turn clear on the chlorine drop test. Needless to say I was worried, called my pool guy to complain, and took a sample of the water to Leslie Pool's for testing. I tried this test 10 times and always the same result. My pool guy and Leslie pools both said the chlorine was at 5 ppm.
So I emailed TFTestkits and they sent me a new R-0870 and R-0871. When I tested the chlorine now (2 weeks since the last time I checked it) it took 20 drops (so 10 ppm) which still seems high. I have a poolmaster kit and it is showing 2 ppm. The Taylor kit that it comes with is pretty difficult to see the difference in the colors but it appears to be between 2-5 ppm. I haven't taken a sample yet to Leslie Pool Supply for their reading but I really doubt it's 10 ppm. I've been using the poolmasters kit for a long time and the color is significantly lighter than it was when it was 5ppm.
What am I doing wrong?
