My pool builder is requiring weekly testing by a 'professional', such as Leslie's. This is due to ongoing issues with my plaster and what the plaster and manufacturer of the plaster say are imbalances in chemicals. The pool was no drain Acid washed a month ago. Plasterer wants me to keep the PH at 7.2 which is impossible. We have unplugged the SWG (too cold anyway) because plaster says the salt cell is causing the issues. He keeps changing his mind as to what the issue is. My plaster is rough now, unfortunately. I am also still adding acid at about the same rate as I was before with the SWG on.
I have been having it tested but my numbers and pool store numbers are not the same ...I had it tested at Leslie's yesterday (drop tests) and then another place today that uses a fancy electronic device. I was more curious than anything to see how it came out. My tests at home today and yesterday were pretty consistent with each other but inconsistent with the stores. I realize that the stores are unreliable, but it's what the builder is requiring me to do. I'll post my results and both pool stores below.
Here is my question, with numbers different from two separate places and my numbers not counting, according to the builder, how can I make my case? Plaster and manufacturer say my PH is too high. I am seeing what appears to be the start of calcium nodules on the sides and bottom of the pool...
I just added CYA starting Monday night so I didn't test for it today as it wasn't all dissolved yet.
my numbers today and. Did not add any acid after Leslie's tested it.
FC:4.5
CC:.5
PH:7.4
CH 275 (this has risen since the acid bath -it was 225. We have had rain)
TA: 100
Leslies - yesterday -drop test. They did the quick chlorine test like the daily one in the TF-100 so I don't know how he got an accurate number.
TC:4
PH: 7.6
CH: 250
TA: 120
Fancy Pool Store : today
FC: 3.7
TC: 3.7
PH: 7.7
CH: 301
TA: 82
CYA: 25
FC:4.5
CC:.5
PH:7.4
TA: 100
TC:4
PH: 7.6
CH: 250
TA: 120
FC: 3.7
TC: 3.7
PH: 7.7
CH: 301
TA: 82
CYA: 25
