Hello,
I got my TF-100 kit this afternoon and I know you're supposed to have the pump running for a bit before testing, but I was too excited and only ran the pump for 25 - 30 minutes before testing.
Here is what I got:
FC = 33ppm
CC = 0
TC = 33
CYA waaaaaaay below the lowest gradation on the cylinder. If the 100 mark is close to the half way point, mine was less than quarter of the column.
( I guess that means the CYA is high? )
I didn't measure Ph but when the pool guy came on Tuesday he showed me it was around 7.4 or 7.8. I'll measure again tomorrow and post.
This is a pool that I inherited that has apparently had an algae problem and I definitely see it when I brushed the pool again this evening. Cloud of green from the wall.
What should I do next?
Increase CYA and then SLAM??
Thanks a lot !!
Here is what I got:
FC = 33ppm
CC = 0
TC = 33
Thanks a lot !!
