I've been using the Taylor DPD kit via Leslie's. I've also diluted the test sample 1 to 1 and then doubled the test result when the test results went off the scale. It would be nice if the Cl test were a "clean" titration with an easily discernible endpoint, as is the Taylor test for total alkalinity. Anyone who took college chemistry knows what I mean by an easily discernible endpoint.
Question: I've occasionally left the Cl tested sample capped in the test cell sitting out for several hours. After this time the reading seems to have climbed quite a bit. Does this mean anything? Also I have the Taylor salt test, which indicates much more salt than does the SWG board, the Taylor test gives 4900 ppm, as compared to the cell reading 2800 to 3000. Leslie's has as salt test meter which agrees with my SWG board. Any thoughts on this large discrepancy? A few hundred ppm I'd attribute to margin of error, but almost 2 to 1 seems a bit much.
