I have the Taylor K-2006C kit. I bought it several weeks ago when i had algae so I would know where I stood when SLAM testing. Using LC only i conquered the algae and now have a clean sparling pool. During the SLAM I only tested for FC and CC until I passed the OCLT.
Today I began trying out the other kit tests for the first time and have a few questions.
FC 20 - got this one down during SLAM.
CC - less than 0.5.
CH - 350 which is OK?
TA - I could not get the sample to turn from green to red (did change to clear but not red even after 100 of R-9000 drops were added ). Could this be because my FC is still around 20?
PH - i could not get a color match to the text tube colors. Is this also due to the high FC?
CYA - i got this test down pretty well after 3-4 tries using the same solution all tries. Is it Ok to use the mixed solution more than one try in the black dot test?
SALT level testing - though there were instructions for performing this test i could not do as the kit did not include the reagents needed to perform. Was the kit supposed to have them? If I purchase is this test really accurate.
Feedback/responses to my questions will be greatly appreciated
CC - less than 0.5.
