Hello everyone. My brother just bought a house last month and we have been working on his new place. I am a electrical contractor and have been doing electrical work for 11 Years now. We were adding GFCI protection to his pool pumps and noticed the wires from the INTERMATIC MULTIPURPOSE CONTROL MECHANISM MODEL: P1353ME feeding the pumps needed to be replaced. As I was taking the wires off the terminal board the terminal broke off. I did not put much pressure on it and snap. I think it had been overheated but looking at the copper wire was discolored. I was looking online trying to find replacement part but not having much success finding information on my options. Thank you in advanced.
LR4642 E44549
Polaris P-60 Pool Pump
BP-60B, 15 Amp, 3/4 HP
HZ 60 RPM 3450
Volts 230/115
Amps SF 6.4/12.8
2 Speed High/Low
Jandy
Century Centurion
SHPF2.0HP/SHPM2.5HP
The other pump is a 2 speed pump and the terminal board I would like to replace as well
Jasocr2199
LR4642 E44549
HZ 60 RPM 3450
Volts 230/115
Amps SF 6.4/12.8
2 Speed High/Low
Jandy
Century Centurion
SHPF2.0HP/SHPM2.5HP
Jasocr2199
