There are two sensors.. Both the same. One goes into your pool water piping not sure it matters where and measures your water temperature. Held in by a band clamp..
The other is the air temp and is just left sticking out the bottom of the enclosure.
No it's not a freeze plug. You drill a 3/8" hole into the plumbing after the filter and the probe is secured with a band clamp. That's really the only way it will work.
