Hi all,
So I went to the pool store today to get some muratic acid.
Took my water in for them to sample so I could get $5 off my acid purchase.
Surprisingly, their results were very close to mine.
They gave me spill on "you have high phosphates and need something to lower that"...I just said no thank you.
Then, he asks me what kind of shock I'm using. I told him I don't use shock...I just keep my chlorine level where it needs to be....however, if I had a need for shock I would use it (like right before I go on vacation to get the FC real high). He then said chlorine alone doesn't sanitize the pool...again, I just said no thank you.
The one test result that I didn't know about was TDS.
He said my TDS is high because I use liquid chlorine.
Don't know if that's true or not....and if it is, how does TDS, if at all, hurt my pool/plaster?
The TDS reading was 2300.
I imagine like CYA, the only way to reduce that number would be to drain some water.
Thoughts?
Thanks!
Thoughts?
Thanks!
