Taylor PH vs Amazon PH meter
Philly_Mac
54
Philadelphia
Hey all,
I’m getting two different readings on Ph.
Taylor is reading 7.6-7.7 ( which is my target)
However a meter I purchased from Amazon (7$) is reading 8.1
Pretty far off reading. I calibrated with distilled and on Friday it was at 7.7 on the meter
Taylor is showing a nice light pink 7.6 range. And meter is showing 8.1. My question is which result would u trust. My fc is 7.5 (100cya).
Is meter is the way to go please provide suggestions on a good quality meter.
Thanks all
You get what you pay for.
How reliable is the Taylor ph test? I’m fine with not using a meter at all. But figured I’d give it a shot. Figured not to trust the cheap meter.
I just ordered the apera, lets see if it’s the meter or Taylor drops giving the false readings.
The meters all have to be calibrated, cleaned, and often stored in a special solution with regular makntainence. The drop test doesn’t require any of that, except maybe replacing it every two years.
Question, does high chlorine levels (7-10ppm) affect ph meter results the same way it can affect the drops?
If so, I’m assuming I would have to add a chlorine neutralizer. Not sure how much I would have to add to the water sample (considering a larger sample for meter)
No, not until FC gets above 10.
And with high CYA levels yiu get a good pH reading between 10 and 15 if you read the test immediately.
You don’t need to test pH with high FC.
Reactions: Philly_Mac
Got the apera today. Calibrated (two point 4 and 7) and showing 7.7 so I’m good.
Took me a while to realize you need to rinse the sensor with distilled water before and after each reading for the calibration.
Also can take 1-5min to stabilize when testing tap water (pool water). After that the reading was spot on.
Thanks for the suggestion on the meter!
Glad we could help.
TFP is a member supported 501(c)3 non-profit that is volunteer staffed and has no ads. Your support keeps the servers running so we can be here to help you. It would be helpful if you considered supporting TFP so we can be here to help in the future....
Reactions: oledan
