Tagelus 1.5" MPV - threading on outside of ports??
ipfhliyl
14
North Central Ohio, USA
I poked around quite a bit but couldn't find what fittings the threads are meant for. Called PB; he couldn't tell me either. I'm hoping it's not proprietary ...
The internal threading is for 1.5" male fittings; I was hoping the outside was for 2" female fitting, but no.
Any experts who might give me a lead?? Thanks!
1poolman1
In The Industry
Jul 14, 2014
30
Sacramento
If they are truly threads, they are for bulkhead fittings that Pentair used but I have not seen available separately for a while (and, being Pentair, were rather expensive). Try these if you want to have removable fittings for your filter: CMP 2 in. MIP x 2 in. PVC Hi-Temp Union UNHT20 21063-200-000 – 2 Pack
I have used them for years and they work well.
sktn77a
1,443
Chapel Hill, NC
I don't think they will work - the OP said his internal (female) fittings are 1.5". They make a similar union fitting in 1.5" but any 1.5" MIP fitting will work..
1poolman1
In The Industry
Jul 14, 2014
30
Sacramento
Sorry for the mis-information. I meant these: CMP 1.5 in. MIP X 2 in. PVC Hi-Temp Union 21063-160-000. I especially like that, while you can use Teflon tape, they usually seal well with the "O" ring that comes with them
ipfhliyl
14
Sorry for the bad description. I was talking of the threads on the OUTSIDE of the port. The inside threads are 1.5" female that accepts 1.5" male PVC adapter. I finally got a response from Pentair (4 days) that they sell a union kit for which the outer threads are designed. It appears unavailable in single union (after searching usual online suspects), just 2- or 3-piece "kits" in which I have no interest.
I'll just get a 2x1.5 male adapter from the big box store (don't care to wait on shipping!!).
Thanks for the responses, anyway!!
ipfhliyl
14
Sorry for the late response. I did finally hear from Pentair; there is a union kit for the threads. Problem is I'd have to pay for 3 unions when I need only one. I've taken the simple 1.5" threaded male PVC route.
