TA seems high and not dropping
db1234
Active member
Aug 6, 2018
35
Barrie, Ontario, Canada
Hi
My TA is a little high and not dropping. I've brought PH down but unsure how to follow up.
Also, being in Canada, is Windsor Ice Melt what I should be using to increase CH. I've added a couple times but not getting the CH increase I'd expect.
The label says Sodium Chloride CAS #7647-14-5
mknauss
33,850
Laughlin, NV
You are sharing your Poolmath. That is how I looked at your data.
I am not sure in Canada. Ice Melt is one thing I would think you would have! Especially in Barrie --- been there! Nice Cabelas.
Canadian Tire tends to carry pool chemicals. Try them.
Chasarms
347
Dardenne Prairie, MO
My experience is that TA is pretty illusive. I’ve put nearly a gallon of 31% MA in my pool over the last few weeks and the TA hasn’t moved. No sure why, but I’ve been advised not to worry too much about it.
