- Sep 21, 2007
- 115
- Vinyl
- Hayward Aqua Rite (T-15)
My hot tub numbers are:
Bromine 5
pH 7.6
TA 85
My hot tub has pillows that detach from the tub.
They look like they are made with some type of plastic/foam.
Last week I noticed that the pillows were shedding foam debris into the tub.
When I went to the pool store where I purchased the tub, they indicated it was likely due to pool chemistry.
Even though I test my water using my own kit, I occasionally drop in to have them test for me as well while I'm purchasing equipment or supplies.
The stores recommended TA for a hot tub is 100-150, my tub is typically around 85.
So every time I go in, they recommend increasing TA with buffer/baking soda.
They indicated that the low TA could cause pH to fluctuate out of range.
Whenever I've tried to get to their targets, I fail.
I'm finding impossible to achieve a target TA of 125 and keep pH in range. (similar to Going Crazy with ph/TA)
TA and pH both increase with baking soda, and decrease with acid.
I find it hard to believe that pillows are shedding from low TA causing pH fluctuations.
Is it more likely that they are shedding from the addition of Baking Soda trying to achieve TA=125 which spikes the pH out of range.
I'm afraid my warranty claim for pillows might be stuck between what makes sense on this forum vs pool store TA targets.
Any advice?
Bromine 5
pH 7.6
TA 85
Any advice?
