TA and PH with a bit of CYA
JaySee
65
Toronto
Hi,
Just passed my first SLAM 2 days ago, and am now doing adjustments for PH and TA.
My readings are:
FC : 5.5
CC : 0
PH : 7.4
TA : 110
CYA : <30 (dot still visible at 30, and visible when tube is filled to the top)
With my PH is acceptable, should I be worried about the high TA at this point? I've pointed the returns up to aerate to get the PH a bit higher.
Also with the intermittent rains messing with my CYA, should I throw a chlorine tablet in the skimmer to bring it up a little bit? The previous owner has a last supply of tablet and I've only been using liquid chl so far.
Thanks!
Don't worry about TA. At 110 your pH may drift up a little faster, but the fix for a high pH and a high TA is the same (MA).
You should focus in bringing your CYA to 40 (or at bare minimum 30).
If using tablets, use a floater. Adding chemicals on the skimmer can damage your pump/filter/heater.
No need to "worry" about TA, it will come down as you bring PH down..
Get a puck floater, never put them in the skimmer.. yes, you can use pucks to bring your CYA up slowly while also getting chlorine... :)
Thanks everyone!
Is it ok to leave it floating around even without the pump turned on? I turn the pump on overnight, and read somewhere that a puck left in a floater without circulation could cause chlorine to build up in one spot and 'damage the pool'.
