Hello,
I received my Intex 14 inch sand filter yesterday and I'm going to go attempt to hook it up today. The pool has been set up and in use for over a month, using the cartridge filter. Any pointers or guidance for switching out after the pool is already filled would be greatly appreciated. I assume I'll just use the little black plugs on all three inlets/outlet, hook everything up and follow directions, then unplug.
Also, my pool has two inlets (water out of pool to filter); do I need to use both of them or can I block one off? I'm also concerned that the new pump, being more powerful, will be an issue with the smaller 1.25 in. outlet (water back to pool), as I'm not brave enough yet to cut a hole in my pool for the larger nozzles. Does the smaller size tubing ever cause too much pressure in the pump? The manual shows pictures of how to attach the adapters to make it work, so I am hoping it will be fine.
(intex 14x42 AGP)
(intex 14x42 AGP)
