Hi welcome to TFP. Chlorine strength varies so you need to look at that where you purchase. Look for % Sodium Hypochlorite. I have purchased 12.5% from Leslie's, 10.5% from Pinch a Penny Pool, and 10% from Home Depot. You need to put the proper % in your Pool Math app to calculate the proper amount you add each day. Also Pool Math app has a feature where you can calculate the price per % of chlorine based on what is type of chlorine is available in your area.
Manually using liquid chlorine will not be as easy as using pucks - just want to be clear on that point. It will require daily dosages. As a rule of thumb - 1 gal liquid bleach per 10k gals will raise Chlorine 5ppm. Obviously this slightly varies if you are using 10% or 12.5% chlorine. Suggest you test daily to get a feel for your pool and environment.
I purchase 3-4 gals at a time. Currently I am adding 1 pt to 1 qt a day depending on usage, rain, sun, etc. I have nearly same size of IG pool. Chlorine does have a shelf life so don't buy a very large quantity at a time unless you can store it properly.
If you go out of town, you may want to go back to pucks just for that timeframe unless you have someone that can come daily to pour chlorine in your pool.
Some people have set up an injection system using a 10-15 gal tank. This makes it more convenient and similar to using the puck process It is something to consider if you have the time to do that. One version uses a Stenner pump which is low volume and can be set up on a timer.
I can't speak to Calcium issue but suggest you read the info on ABC of Pool Chemistry.
