- Mar 25, 2019
- 554
- Plaster
- CircuPool RJ-30 Plus
It’s always been a bit touchy. The clamp needs to be tapped here and there as you tighten it but this time I can’t get it to stop leaking. It recently froze, although I left the pump running 24/7, I found it leaking after and I can’t get it to stop. I cleaned everything up and re-lubed the o ring. I can’t find any damage to the housing. The clamp has flaking paint but it’s not damaged either. Should I just try a new o ring? It’s one of those big ones with metal in the middle.
