Hi gang,
I am trying to help friends move to SWG. I just concluded a SLAM process with them and explained why their pool guy was failing them dumping liquid chlorine in their pool once a week...... They are ready to move to SWG and fire the pool guy.
Pool is ~20,000 gallons per original pool builder. However, based on measurements during SLAM, I am guessing closer to 22-23,000.
On to SWG selection and installation. They have a Pentair Intelliflo vs-3050. They do not have automation. I would recommend an IC-60 but am realizing a couple of issues.
1) The pump and SWG do not integrate without automation control.
2) Without automation, would require separate timer for SWG and have be manually synchronized with pump timer?
3) Warranty only valid if installed by certified Pool Company.
4) If installed vertically, flow must be up. They have a perfect place but flow is down..... Not a big deal but just some extra plumbing to install it horizontally.
I’ve been reading other posting but don’t have a clear view of how to define and characterize different options and ultimately a recommendation.
Simplest, but most expensive, is automation and IC-60. However, not sure on automation options and selection.
Other options are to add timer and power pump and SWG from it. I read the pump will maintain memory for at least 24 hours. This seems to complicate the controlling of two functions a bit and feels more like a band aid.
I am 100% open to your thought and wisdom.
