- Apr 25, 2022
- 293
- Plaster
- Hayward Aqua Rite Pro (T-15)
For the past month my SWG is on a higher setting, but not producing the same as it was. It’s still producing chlorine, but previously I would have it on 10% for a FC level of 5. Now I’ve got it on 50 and I can’t get the FC over 4. I don’t have CC. I pulled off the cell and rinsed it - it was very clean, but I thought that it may need it because it wasn’t working as it should. It didn’t change. I added salt as I emptied the pool a bit a couple of weeks ago and had the salt cell on for a few minutes as omnilogic turned it back on without me realizing it. But it seems to have recovered and is still producing chlorine - I tested right from the return and it’s got plenty of chlorine coming in. And it’s maintaining 4 on a setting of 50%.
Is there a reason this is happening? Anything I can do to get it to work more efficiently like it was. I turned it up to 80 today hoping to get it back to FC 5 in the morning. Or could it be that’s it just really really hot right now? Which it has been for a few weeks here in Florida.
I’m just a bit confused as the pool is very well balanced, I’ve never had a drop in chlorine and I test for FC and Ph daily. Oh - and the Ph seems to be remaining stable at 7.6 which is also a bit odd. Usually each week it rises again to 7.8 and then 8. I run the pump 24/7 - 3 hours on high and the rest on low. Just not sure if I have a problem or I’m just experiencing the side effects of Florida summer.
