I noticed some algae on the corners of the pool so I checked the water with a strip test. The strip Showed no chlorine. I went and checked the Aqua Pure board and nothing indicating any errors. It had the Flow light green and indicated that it was running at 90%. Pulled the cell and it looked relatively clean but I cleaned it anyway. Put a bag of shock in with some 3/4 gallon Hydrachloric acid (test said PH was high) and let it run over night. Got up and checked again in the morning and the strip indicated that everything was in normal range. Tested again later in the day and it showed no chlorine again. Decided to take a sample to a store and have them test it. These are the results:
Free Chlorine: .22
Total Chlorine: .49
PH: 8
Tot Alk: 158
Calcium Hard: 186
Cyanuric Acid: 5
Iron: .1
Phosphates: .1
Salt: 2830
It appears that the equipment is running fine but the chlorine levels are not there. What should I do?
Free Chlorine: .22
Total Chlorine: .49
PH: 8
Tot Alk: 158
Calcium Hard: 186
Cyanuric Acid: 5
Iron: .1
Phosphates: .1
Salt: 2830
