DAB942
I'm doing the same. Even though I want to know how it works, my main concern is that it does. Knowing how it works will better help me dial it in. In the end, I just need it dialed in.FC level at 7:00 am after running the cell for 9.5 hours at 100% is 9 so that's a total gain of 2.5 FC.
Pool math app calculated it should have risen by 6.1.
Going to turn off the cell and test the FC level in the late evening to determine daily FC loss.
My inclination is the manufacturers list the cell performance based on very specific criteria and operating environments, similar to how car manufacturers list their EPA fuel mileage. Sure you can hit those mpg numbers if you tape the doors shut, run 0w oil, inflate the tires to 100 psi, etc. etc. but real world performance will never reach those figures.
That translates to 24 mg/hour. That's very close to what I see, especially given the FC test's margin of error. When I use 25 mL to test for a 0.2 resolution I see 19 mg/hour.FC level at 7:00 am after running the cell for 9.5 hours at 100% is 9 so that's a total gain of 2.5 FC.
The Hayward T-15 is pretty close to advertised. I have tested over a wide range of salt and temperatures and it is fairly linear with amps. Production ranges from 1.14 lbs/day up to 1.6 lbs/day. Average of all test results was 1.43 lbs/day which is very close to the spec of 1.45 lbs/day. The average production coefficient is 0.24 lbs/amp/day.Has anyone else run this simple test? Do all the other SWGs tested produce as advertised?
I've got an Inyo Pools Crystal Pure 60,000, a Hayward clone which is rated at 3.18 lbs per day. In my 30K pool running it at 100% it should yield about 0.5 ppm per hour. Last night I ran it for four hours at 100%. It started with FC at 7.4 ppm (37 drops). After two hours FC was up to 8.6 ppm (43 drops) and after another two hours (4 hours total) it was at 9.4 ppm, (47 drops). So base on this, it look like my SWG is producing at around it rated production of 6.18lbs per day.
Note that when generating, the voltage is at 21.8 and current is 6.4 amps. Voltage when not generating is 28.5
I think there might be some of that and that’s probably to be expected. I mean the real world is often different than test conditions, and of course the manufacturers want to make their product look better than everyone else’s. But at some point it crosses the line from being overly optimistic to being downright deceptive.
Using your car example, if you bought a car that promised 35mpg you realize that when you are driving it you might only get 30 mpg. Maybe even 25 or 28 it you were driving it particularly hard or in sub optimal conditions. But if you routinely got 13 mpg that just wouldn’t be right.
Along the same lines, I think if the manufacturer is promising an FC rise of 6.1, but you only got 5.5, or even 5 then people wouldn’t really think twice about it. It’s just likely that the real world conditions are different than the test conditions. But only seeing a rise of 2.8 seems way outside of being reasonable.
Yes, I'm using a 25ml water sample which then has each drop of the reagent equal to 0.2 ppmAre you using a different method than FAS-DPD Chlorine Test - Trouble Free Pool
(Edited for clarity; I'm using a 25ml water sample which then has each drop of the reagent equal to 0.2 ppm )
Now it's producing more than 6 lbs per day?So base on this, it look like my SWG is producing at around it rated production of 6.18lbs per day.
