The charts are at 77 degrees Fahrenheit.
If your water is warmer, you will have higher conductivity.
The readout is µS. They call it a "hardness meter" for some bewildering reason which is probably related to marketing. When you put it in a standard 45 µS calibration solution it reads 45 on the display. I'm just comparing because the controller is also using conductivity. As far as I know there's no way to test for actual salt levels electrically.Because the water hardness meter is reading for TDS, not salinity.
That will only reduce flow rate by about 3 GPM. Was the 10 & 12 PSI in pool or spa mode? They should be different pressure.It's not appreciable different. About 12 lbs.
It was as you suspected: The modifications on the returns made zero difference on FC production. The good thing is that now I can put valves on the returns and regulate the output of the pump.
That is correct.The salinity meter is just a conductivity meter with a different scale built-in.
The 12 psi is spa mode (suction and return from/to spa). On pool mode it's about 11 psi right now.That will only reduce flow rate by about 3 GPM. Was the 10 & 12 PSI in pool or spa mode? They should be different pressure.
That's a great idea. I've been wondering whether everything's being fooled by high conductivity due to our hard water and years of topping off (still waiting for the Taylor 1766). We don't get enough rain to dilute the water, just lets me avoid topping off the pool with the hose sometimes.Earlier you posted that the voltage was around 20.5v. In the manual, they specify a range of 21-27v. At 6.5 amps, I would expect the voltage to be a little higher than that and not to reach the minimum specification until the current increased to 8 amps. One additional experiment would be to raise the salt level in the spa until the amperage approaches, but does not exceed, 8 amps and see what the voltage on the unit is as well as the production. This should be the most efficient operating point.
Maybe a missed labeled RJ20+ (0.9 lbs per 24 hours) cell?That's exactly in line with what I was seeing before - about 1 lb./day.
