Long time lurker, first time poster. I figured I'd share my simple and reasonably inexpensive solution to powering on a salt water generator (SWG) with a pool pump and no automation. Parts: Digital Loggers Power IoT Relay II ($25 on Amazon) plugged into a 120VAC outlet; Veris Hawkeye H822 solid-core current transducer (CT) 0-5VDC output ($25 on Amazon); Circupool Core35 SWG; Pool Pump (in my case a Pentair Superflo VS); 16AWG wire to connect the CT to the IoT relay ($2? from Lowes). The Power IoT Relay is essentially a power strip with 4 outlets (1 always on, 1 normally on, 2 normally closed). The NC outlets turn on with > 3 VDC from the CT.
Plug in the IoT relay into a wall outlet. Plug the Core35 SWG into a NC outlet on the IoT relay. Install the CT on the hot wire of the pool pump. Run the 16AWG wire from the CT to the IoT relay. Start pump and watch the green light on the IoT relay turn on indicating power to the NC outlets and the SWG! I'm also connecting a Circupool TotalBalance pH controller to the second NC outlet.
NOTES:
(1) A nearby 120VAC outlet is required.
(2) In my case, one pass of the hot pump wire through the CT only outputted 2VDC when the Pentair Superflo VS pump was running at 2800. After winding the pump wire three times around the CT, the output was raised to over 6VDC and enabled successful operation of the Power IoT relay to turn on the SWG when the pump starts.
(3) I purchased the Core35 specifically because it would plug directly into a 120VAC outlet for this solution. Other SWGs will not be as simple as the Circupool Core series.
(4) And finally, the Power IoT relay is rated for indoor use only (mine is currently installed on an enclosed porch so not sure of its life expectancy in humid Florida).
And apologies in advance... I don't have my pool specs in my profile.
NOTES:
