I put my response here to not derail the OP's thread for help
Question:
"When set at 80%, the cell is allowed to rest 20% of the time while the pool pump is running prolonging the cell life."
The way I understand it:: the hours the cell runs is the cell life, that is why an oversized cell lasts longer, because it is run for shorter period of time to achieve desired chlorine levels.
Question:
From the Pentair Manual:The life of a cell is from the amount of CL generated, not the hours run or the water flow through it. If your pool water volume needs 1 lbs of chlorine a day it does not matter if the cell generates it in 6 hours or 24 hours. SWG's egenrate chlorine slowly so you have a minimum runtime to get the desired CL generated. 6 hours at 100% or 12 hours at 50% or 24 hours at 25% all use the same amount of cell life.
