SWG Install and Opening Help
Except for possible loss of sleep, no downside to doing an OCLT.
The flow switch does cut power to the cell, so essentially the same as turning it off. But flow switches are meant to be a backup safety, and not a primary on/off control. They do fail (mine did, after a year!) Better to bump up the low to allow the SWCG to generate all day, and dial it down in the settings, so you still meet your CL needs. Turn down your high speed setting (rpm or time) a bit, if you want to balance the energy savings.
As long as there is the minimum flow, the SWCG will generate the same amount when getting power, no matter the amount of water through it. The % setting on it is not a real "strength or concentration" setting, it is a timer - so while getting power, turn on for 50% of the time, turn off for 50%, etc. Therefore the same effect over time as if it actually could directly increase/decrease the amount generated. Let the box control the on/off cycle, and keep your pump up just enough to allow it to do so at any time in the day. Then the flow switch can fill its real role as a backup safety.
Did not pass the OCLT. I also decided to check my CYA again after reading the page on here on how to do it. It's much more descriptive than the sheet that came with the test kit. I've been using 40 as my CYA but this morning it tested at 50. I know CYA won't just go up, so I'm assuming I've been doing my SLAM at a slightly lower than required FC level.
Also I've been brushing and vacuuming daily and every day there looks like new dirt on the bottom. I assumed this was environmental stuff because we've had a lot of storms recently, but is that just dead algae? The pool seems clear and all ladders and steps are out and I brush walls, skimmers, and weir doors inside and out. If that is algae dying off I guess not seeing that anymore is a good sign when it happens?
Likely a combination - dead algae and dirt. Brushing alone gets it kicked back up into suspension in the water. Then taken out by your filter. But depending on a host of factors, the filter only gets some percentage. The rest resettles. Along with any new dead things and dirt. A manual vacuum or a robot gets a lot more of the "stuff" directly to the filter, and far less to resettle out. The OCLT and CC reading, with having very little settle out, will tell the tale. Especially at the start of a SLAM, it can be very surprising how much you see on the bottom each day - a lot more suspended and now killed than the clarity of the water might suggest.
Especially rain, but also wind, can bring in more dirt. Sometimes a lot. So don't assume you have algae again right away after the SLAM. The CC will give a flag, and then the OCLT can confirm. Once you get into the swing of what is normal for your pool, you'll get pretty good at judging how concerned to be. If you always keep your CL at the high end of the recommended range (or even join #teamrunhot by being a bit above!), the odds of growing algae go way, way down. I normally don't think about algae, as long as my CC is <= 1, pool is TFP clear, and if there is an environmental reason (wind/rain) for the "stuff". Then I just assume dirt and brush or vac to make it pretty again.
BTW - update your signature with details about your pool. It helps a lot for us to tailor the information specifically to you. Create Your Signature - Further Reading
If you pay the outrageous (grin!) $8/yr for the PoolMath app subscription, you can link your logs by using the same username as here. Then we can easily see your history of readings and chem adds, to further refine answers to problems. Click on my user name to see the logs for how I am lurching toward a balanced pool.
Every little bit helps and all, but its not going to change the price of beer. Thank Heavens for that. (y)
Some people put very little effort in and its low single digits by the time they dose. Id rather see steady 12s when it really should have been 16, then 16 to 2. (Etc).
When Mother nature is shedding its impossible to know how much is which. The failed OCLT says that at least some of it was algae.
Timeline update. I shocked Monday night enough to get it up at FC of 20. I typically don't check again after I add, I just add and go to bed. Tuesday morning it was pouring, and I grabbed a sample at 6 AM and it was FC of 18. I decided to let it go throughout the day. I checked again at 8 PM and it was FC of 15. I decided to do another OCLT and this morning at 6:15 it was 13.5, so still a failure. At this point in time I've gone through 17 gallons of LC and only have 1 left, so I'll need to run out and get more. We're getting there, slowly, but we're getting there.
Wednesday morning I put in LC to bump my FC up from 13.5 to 20. I tested at 8:15 PM and it was at 20 FC. I'm guessing my pool isn't as big as the company told me because I'm fairly sure when I add what pool math tells me to it goes over my expected FC. Anyway, I tested at 5:40 AM this morning and my FC was 19.5 and my CC was 0.5. Once there's a little more sunlight I'll go out and see if there's any visible dirt in the pool as I vacuumed yesterday around 6 PM. If all looks good I think that's considered a finished SLAM.
Side question. I will be cleaning my stairs and ladders and putting them back in this weekend I hope. It's been raining for the past week or so, so there hasn't been a good time to do it. Should I keep my FC levels up to SLAM for a day or two post putting everything back in just to make sure there isn't anything left over after my stair/ladder cleaning?
Holding slam for an insurance day or three is real easy, as you're seeing. (Great job getting here BTW)
Now think about how much fun it was when you started.
Yeah there is a smidge of dirt in the pool, but I just think that's normal because our pool is surrounded by a garden bed and trees. I'll clean the stairs and ladder tomorrow or Saturday and hold the SLAM until Sunday into Monday to be extra sure. Last thing I want to do is put those back in and undo all this work.
So i cleaned the steps and ladder Saturday morning and put them back in the pool. Checked FC at 9PM Sunday night and it was at 13 and CC was .5. Monday morning at 5:30 FC was 12 and CC was .5. Water has been looming clear for a while so I think my SLAM is complete. I'll let my FC drop below 10 (shouldn't take more than a day based on what I've been losing when it's sunny) and check and dial in my CYA and Ph. Then will be the process of dialing in my SWG percentage.
FC dropped below 10, here are my most recent pictures (still a lot of cloud cover) and full test results:
FC: 9.5
CC: 0
Ph: 7.9 or 8? See picture, I have trouble differentiating similar shades.
TA: 60
CYA: 50
CH: 175
Salt: 3400
Based on this i think I want to add 56 oz of dry stabilizer, which will also drop my Ph about 0.4, which i think is perfect. After that I'll test again and start using the SWG unless there is something else I should check or do first. Appreciate all the help.
