Does the SWG unit work appropriately if the flow direction is changed? The SWG will always be on the downstream side of pumps and filters, but I want to place it where flow will sometimes be reversed. I have both a DE filter and a sand filter, each with their own dedicated pump. The DE filter is in service most of the summer, but I switch to the sand filter in the fall and spring when the chunkier stuff starts hitting the pool. The best spot to install an SWG will see different flow directions depending on which pump/filter is being utilized
