I think I have some problems.....Day 5 of shocking
1. I had to backwash last night (pressure went up 8) which led to refilling the pool about 3 inches. It lowered the CYA some...to between 60 and 70 per the test.
The pool lost 10ppm FC overnite (25 to 15). cc is 1 ppm so that's down from 3.5. It also rained some. Not too heavy.
Sounds like you are getting there. Keep above your shock level! I would stay above 30 ppm as much as possible now (I used the more aggresive http://www.troublefreepool.com/pool-school/chlorine_cya_chart_shock for 80 ppm) CYA
2. I don't have enough powder to get through the weekend. I ordered it but it won't get to me til Monday.
You may have to do a dilution and test with DPD or OTO until you powder comes
3. I think I have filter issues. Before I left for vacation (end of June) we noticed that there was something "white" coming of out all the returns. Looked a lot like DE. When we got back we took the filter apart, cleaned the grids, resealed the oring and pipe with sealant. No tears in the grids. They looked pretty dirty so we soaked them overnight. Put it all back together. The wate has been sparkly clear for the last few days since I started shocking. Last night I had the pool light on and noticed the "white" stuff again. Only coming from one return....the one closest to the filter. And much better than before but still there. Did the same thing. Took it all apart. Wasn't too bad. Did notice there was somehing "pink" on one of the grids....very small triangular area at the top of one panel. Didn't have any acid to soak but rinsed with hose and it went away. Reassembled. Still have the "stuff" coming from that one return. Could the filter be leaking DE? I do have a multiport valve and i've read some stuff to where that may be the culprit??? And what is that "pink" stuff???
I am not sure on this, I have not worked with DE filters, maybe someone else has ideas here?
This is day 5 of the shocking process and although the water is sparkling and we have gone over every inch of the pool surface for algae I see no end to this. I'm ok with the process but I can't keep running the pump 24/7. I won't be able to afford the electric bill which will probably exceed $1000 given June's bill. HELP!!
5 days plus is not unusual for the process, hopefully yours will not take much longer. Again, stay above 30 ppm at all times while you are shocking, and that should keep the process moving as fast as it can.
