I have read multiple posts through the years about not relying on SWCG flow switch as primary safety. I have a Core 55 and a Circupool Smartflo 1.5hp VSP. I plan on running them 24/7 and saw that this can help negate the need for a timer or anything.
Problem I have is that last time power went out, pump did not come back on...gave AC under voltage detected. When that happened, I had to unplug pump and plug it back in, so in that case, the SWCG will come back on, and if I'm not home, the pump stays off and I'm relying on flow switch as safety.
any way around that? Can SWCG be wired directly to VSP?
