SWCG recommendations
Yep, plan is to lower the timer to only let it produce when there’s daylight hitting the pool. If I have to reduce any more, I’ll probably lower the timer hours even more and keep the SWG at 20% so I can fine tune it easier with a punch button rather than my timers little screw stops.
I figured out my runtime with the SWG production set to 50%.. Then I don't fuss with the timer stops either. I just turn the SWG up or down to accommodate the FC load I am expecting. More bathers, hotter weather: turn it up. Less sun, cooler temps: turn it down. I haven't changed my pump runtime in years.
Reactions: Saturn94
