Depends if you trust them or not. If so, the CYA is a little on the low side, 30ppm would be good. And the pH should be lowered a bit before starting the shock process.
Algaecides are better at preventing algae from starting than killing it. They are not ever needed if the recommended FC levels are maintained. Period.j_walker said:A couple things that have came to mind while researching this is. A few things I have read elsewhere and every pool store I have talked to, try to sell me some sort of algaecide to go along with whichever shock I chose to use. They say there are some types of algae that is resistant to chlorine alone. And if I have one of these types of algae. Shocking without adding algaecide will not work.
If you do not maintain the recommended shock levels, you may never fully kill off the algae ... or at a minimum it will take a LOT longer. This is actually an odd statement from a pool store as typically we hear them recommending adding gallons (pounds) of chlorine (granules) which elevates the FC VERY high ... well above our recommended levels which puts your pool and equipment in danger of damage.j_walker said:The other thing is about maintaining FC shock level. This will come directly from the pool stores staff. I have been told that as long as FC stays above as little as 5ppm it will be in shock level range according to my current CYA level of 20. Is there any truth to that statement or about needing to add algaecide just in case its a rare strand of chlorine resistant algae.
The recommendation of adding algaecide and then lower levels of chlorine certainly would liking end up costing you more money. That is not to say that the employees are looking to pad the books. However, many pool store employees just do not actually understand the chemistry and just repeat what they have been told by the previous employee.j_walker said:I truly value the opinions on this forum which is why I'm here. I also understand that pool supply stores are there to make money. At the same time they need to stay in business. So using there suggested methods may clear the pool but it might take longer which will require one to buy more product from them.
