So I just went out to check it and cycle the vacuum, and it looks like it's at 14 now. I still see waterflow, but my salt cell says no flow. I'll have to go buy more DE. I've gone through 74lbs of it since the beginning of April.
Always keep that in mind, it will remind you to never drop your FC or you will have to slam again.I've gone through 74lbs of it since the beginning of April.
No surprise here. Pool had mud around it for more than a year. This also explains why my filter keeps clogging up. But until I can see the bottom of the deep end, all I can do is keep filtering and vacuuming.OMG, that's pure mud! Kinda shocking to see its still in there after all this time.......
JJ, I see you have a Mastertemp 400, this is what my heater is. Since I turned it on, it is occasionally putting cloudy water out the returns, is this normal operation?Good call on turning off the main drains if there is mud at the bottom. No idea on the red staining, but I would worry about that after your pool is clear.
No, the heater was installed last week. without the heater on, the water from the returns is clear. And it's only a little cloudy the first few minutes the heater is on.Unfortunately, no. I wonder if the same gunk that is in your robot is in your heater. Do you have any sort of bypass where you can bypass your heater until your pool is cleared up?
Who knows what dust and crud was in the heater elements if it was just sitting there. Or if it was plumbed but had no water running through it, it can harbor algea. That is why I run my waterfall every now and then, to keep the pipes cleaned out.Heater is connected and turned on. When initially turned on, the water coming out of the returns was cloudy, and with the heater on, I am seeing air bubbles from the returns. Is this normal? The water always circulates through the heater, and there are no bubbles with the heater off.
I also turned off the main drain, so the filter is only getting water through the skimmers. I want to see if it makes a difference in the filter clogging up. I can see the bottom of the shallow end pretty clearly, but it's still cloudy. Parts of what I can see on the bottom have a red staining, I'm trying to figure that out.
