When I originally filled it two years ago, my water bill was $300 higher than usual for the quarter. I spent $75+tax on DE, and probably $100 on liquid chlorine. I'm not counting the new leaf rake, vacuum, or other supplies I needed anyway. I still have 11 gallons of chlorine left, I'm sure I'll use it during the season.Just out of curiosity, how much have you spent on this process? Would it have been cheaper to just drain the pool and refill it? Here in my town it only cost me about $70 in water to fill 17000 happens, but water is cheap up here.
Drains! The other thing looks like an itchyball, and several shadows of leaves. Filter was plugged up again this morning, so another case of DE is needed tonight, since I only have 6lbs left. I hope that the twice-daily backwashing will be done with soon.I see drains and some other port down there. Keep it up, you are in the home stretch.
Tee hee... I hate it when that happensWell it turns out I did it wrong anyway, I left the SWG on overnight.
THe problem with that is the SWG relies on its own reading to function. When my test kit showed 3400ppm, the SWG had read 4.2gpl, and threw an error code at me that said the salinity was too high.I never believe the SWG device over the test kit. I'm not saying it "lies"... but its not calibrated. Believe the test kit.
Maddie![]()
