My pool has been trouble free and crystal clear all season. I have had a high range TA for about a month 100-120. My PH will slowly drop over the time span of a week 7.8 drop to 7.4. This is also after adding a hour or so of water 2 times over the week for evaporation and use. I have had good chemistry otherwise.
I am curious if the TA hovering around 100-120 should be addressed or is this ok. Additionally when I raise PH I am wondering what others do to raise PH only. I have used PH up from the pool store but this will still raise the TA a little bit too. I am trying to air-ate the water too, but have found it a VERY slow process. I attached recent test results.
TIA!
Regards
TIA!
Regards
