Pool service guy ended up knowing less than I did. His chemistry reports showed balanced water. I did pH and sanitation duties. I could never figure out why I had to use so much MA (about 28 oz a day) I chalked it up to curing plaster. I thought that I was being careful diluting the acid and spreading it out through the pool, but it needed up doing a job on my heat exchanger and the copper leached into the plaster.
The PB recommended the acid wash once the pool was filled back up, so that’s what I did. That was before I met TFP. All our water is from wells, so there are metals. There was some iron staining as well. Through the help of the experts here, I’ve finally been able to get my chemistry right and now it’s just this cloudy water issue.
I added the recommended amount of bleach, but after mixing in after 2 hours, I have a FC of about 21 and a CC of 1. We’ll see how it works out. I have the pump on the lowest speed so as not to jam any particulates through the cartridges. They are 5 days old and no real crud has been through them. I suppose after a couple of days, if it doesn’t get better, i’ll pull them out and inspect/hose them off.
Many thanks to all who have helped me the last two weeks. I’m about beat, and sure would like to swim sometime.
