- Mar 31, 2022
- 77
- Fiberglass
- Pentair Intellichlor IC-20
Well, with all the help from the members and users here, the damage from the lightning strike is behind us. Thank you all for your help. We came real close to having to shorten our season because with the heater out of commission the water was getting too cold. I am now looking to protect myself as much as possible from this happening again. At the time of the lightning strike we had NO surge protection on the house. Now I have install a surge protector at the main panel, all the sub-panels (including the Intellicenter load center), and our A/C disconnect boxes.
I am not sure where the surge entered our pool equipment. I strongly suspect it traveled from the Intellicenter to the Hybird heater along the RS-485 lines but that is just speculation on my part.
I do not have any low voltage lines running from the house to the pool equipment. The only wires running from the the outside environment to the pool equipment is AC power, ground, and a bonding wire. I believe I have done everything I can to protect the AC lines. My question is, is there a way to protect the RS-485 bus and where would it be installed. The equipment I have connected to the Intellicenter via the RS-485 bus is the Intelliflo pump, the Hybird heater, and the Intellichlor SWG. The circuit boards that were destroyed were the Intellicenter Main board, and the Hybiard heater's main board. Everything else survived (including the Intellichlor SWG surge circuit board.)
Again thank you all for your help in keeping our season alive this year.
