Pump is wired for 115v, only thing on the line, 20 amp seimens breaker. Every few days the pump trips the breaker, usually when I stop it and then start it back up. After resetting the breaker the pump turns on, starts its schedule and is then fine.
In the manual the error says the line dropped below 99v. Looking online this seems to happen a lot to people, usually people who have the pump wired for 230v. Also not sure if they receive the same error when their pumps trip.
A common thing others have gotten for advice are to use a seimens breaker, or a pentair branded seimens breaker. I have a seimens, and there is no pentair branded one for 115v that I can find. People also say to make sure the pump is the only thing powered on the line and to have no relays.
I have an on off switch for the outlet, is that considered a relay? Is it possible for a switch to cause a dip in voltage if its going bad/has an issue? Am I wasting my time and should just have the thing switched over to 230v?
For most nuisance tripping stuff I've found it talks about the harmonics/noise confusing the GFCI, but they don't mention an error on the pumps.
Cheers.
Cheers.
