Superflo Error Code
aceofspaids
5
Central Florida
Moved from here.
Helloooo, sorry if I'm butting in on your thread. I see recent activity :)
Recent Pentair problems. Now it's the pump. 7 y/o SuperflowVS-variable speed pump. I looked up the error code (below). My BF (HVAC guy) whose is the guy everyone depends on to fix the tough problems, isn't sure what's the meaning of the error code. I said I know where I can go!
"0F – Absolute AC Under-Voltage Detected: This indicates that the supply voltage has dropped below the operating range of 99v. This could be caused by normal voltage variation and will clear itself. Otherwise, there could be excess voltage sag caused by improper installation or improper supply voltage."
