ok, here is what I am getting with a taylor test kit from Leslie Pools
FC: 2.2ppm
CC: .6ppm
PH: under 7 right now....but I added 2 gallons of muriatic acid this morning...and I am arating
TA: 160 ppm
CH: 40 ppm
CYA: 60-65 (we lost some water and are filling...I expect this will be just under 60 when full again)
OK....so TA is still about 160....since we filled this pool (Intex 32*16*about 48" deep) we have put in over 6 gallons of Muratic acid and letting PH come back up.
Is it really possible our water is that low of a PH? The first time I was getting TA around 400ppm. Is there any harm in just continuing to follow the process....add acid, let PH bounce back up until I get TA in line?
Once I do...will PH continue to rise or will it settle once I have the TA in check?
I live in rural Oklahoma...and on well water.
FC: 2.2ppm
CC: .6ppm
TA: 160 ppm
CH: 40 ppm
