Super 2 lid stuck!
tkdb1089
7
Arizona
Recently replaced my very old super 2 lid with a shiny new one. Fresh o rings and lube, of course.
Now I can't get the darn thing off! And it's monsoon season in AZ... I've got both types of lid wrench, I've tried a rubber mallet, I've tried the WD-40 trick. Can't quite figure out how to effectively use a makeshift breaker bar with the lid wrench.
Any suggestions would be very much appreciated!
Man, I cannot budge this thing, even with a monkey wrench. I don't know if I should just wait for it to cool off outside (in Phoenix that means October maybe) or what. The only thing I can think of at this point short of cutting the Dang thing is to bolt some metal eyes to each end of the handle to put a long piece of pipe or rebar through as a perpendicular lever...
No dice. I still haven't gotten it off. At this point, I'm watching how much is in the basket, just a small number of leaves so far. It's fairly well protected by the rest of the equipment on the suction side. There's a basket on the suction vac line too. I'm trying to give the lid a few taps every day and get it to loosen up. If it doesn't work out, I'll going to get monster channel locks when I'm forced to get the lid off, and accept that it is probably going to break. I'm worried about torquing it too hard and breaking more of the equipment because the pump is not bolted to the pad, so I've got to stabilize it at the same time. Might need a buddy to come over and help. I'm hoping to get closer to the end of the summer before I create a situation where there's more plumbing work or a new pump housing because we had to cave man this thing, hah.
Reactions: JamesW
Some other options I've seen:
1. I used large channel lock pliers on one side with cloth covering the plastic and
2. A rubber maillot on the other side
I was twisting and pounding at the same time on opposite ends if that makes sense.... and off it came slowly.
Alternate with hot & cold water
Tapping slowly with a 2x4 along the lid
Used a strap wrench around the circumference of the lid
Tap with two rubber mallets at the same time
Reactions: tkdb1089
Pardon my drawing capabilities. The green is 2x3 lumber and the red is blocking in between. Make sure blocking is same width as cover handle. This will do it but be careful as not to move the pump and just the cover.Screenshot_20220726-172028_Chrome.jpg
Reactions: tkdb1089
Reactions: JamesW
