Haven't noticed this in my pool until recently. There is a fine sediment that I see gathering in the bottom of the pool. Apparently it is getting through the automatic cleaner and the sand filter. This looks a little like what you get when you use a floc in your pool, but not quite as bad.
Should I vacuum to waste to get rid of this stuff, try a clarifier..... or something else? I did add a little diatomaceous earth to the filter, but so far I'm still seeing this stuff in the pool, especially in the morning when the pool settles overnight.
