Had a heck of a time getting the CYA and FC numbers above zero this year. I was trying to go through some tablets from last year, but finally got in the car and go the raw ingredients to do it right.
While my CYA was hovering around 10 and my FC around 0.5ppm we added some new steps, and boom we got a sudden algae bloom.
Now my numbers look good, if a little heavy on the chlorine
FC 9.0
pH 7.4
TA 110
CH 150
CYA 55
I'm yanking the tablets out and using only liquid at this point, obviously not adding any more stabilizer. Will drain occasionally and let rain help bring that number down a bit. I've been in this state for all of 12 hours, water is clearing but still a little cloudy and green.
That's the story, now my questions
1) Do the steps screw up the water current and make this more likely, or was this just pure coincidence? I grew up with an inground pool, but this is my first experience with an above ground with a single filter/jet so I'm not sure if I should consider this.
2) I know everyone here recommends SLAM, and I will probably do that. But I'm wondering if someone can tell me why I should avoid the "algae destroyer" chemicals at the pool shop? It seems to be working ok so far.
3) Our pool package came with the kontiki 2. Does this thing actually clean, or just mix things up? (KonTiki Automatic Pool Cleaner - Pool Cleaners - Pool City) Is it worth investing in some other sort of vacuum, and if so, is there a recommendation?
4) Is my plan on the CYA reasonable at this level, or should I be draining more significantly?
Thanks for sticking with me on the long post, appreciate any feedback, will be scouring the older messages more once my kids go to bed - sorry if I'm asking oft repeated questions.
FC 9.0
pH 7.4
TA 110
CH 150
CYA 55
