- Jun 24, 2021
- 16,654
- Vinyl
- CircuPool RJ-60 Plus
If you think about a suction side leak and the valves, I think they may act like a check valve. The two o-rings and hard ring around the shaft, I think, can act like a check valve. Under pressure, they are pressed against the shaft. Under suction, I think, they can allow air to pass (like a check valve and allow air in). Now, why 1000s of other's pools, with these valves on the suction side, don't act the same, I have no clue.Seems to me that if the shaft seal is not leaking water out, it won't let air in. That may not be true at all, so we will all wait with bated breath for your test results.![]()
PS,What if I smoothed the faces of the union. 320 and 400 wet or dry. Clean/relube.
Original picture I posted. Two unions to the skimmers, one to the pump and the basket lid.PS,
What union are we talking about???
Got a pic??
