- May 3, 2007
- 18,071
- Plaster
- Hayward Aqua Rite (T-15)
The contractor is not responsive, as I didn't observe for more than 18 months. They have replastered and closed both the main drains in the pool and filled it with water. We observed very recently after installing these waterfalls.
We soaked it in muriatic acid for 3 days and then used hydro jet and power auger to remove as much as we could but there is a "T" where removing the concrete is a bit tough. I was told if they tried too hard then pvc pipe might break. We have removed as much as we can but not completely out which is the reason for asking whether to use a wall suction port as an inlet to waterfalls.Have you tried soaking the area is some muriatic acid? It won't dissolve much but it might release the concrete from the PVC wall.
How far up the sump pipe does the concrete go? It shouldn't be that far up the pipe.
The Wall Suction port is 2 inches.Yes, using too much force could crack the PVC.
I would try soaking it again now that some has been removed to see if it helps.
How large is the wall suction port again? You really need a full 3" pipe.
If you can put it in tandem with the 3", even though partially clogged, it might be ok although not ideal.Does the wall suction port with 2 inches work?
Got it. We have tried our best to clean it but are still left with some concrete. I don't want to have any broken pipe issues.If you can put it in tandem with the 3", even though partially clogged, it might be ok although not ideal.
Ideally, you really want to clear out the MD line if possible.
