- Jul 20, 2007
- 137
- Plaster
- Jandy Aquapure 1400
Finding that i am gaining air in my pump basket. It happens irregularly and seems to be more consistent mid day when sunny. This is a new pool, just filled last week.
Troubleshooting so far:
1) Doesn't happen at all in spa mode.
2) happens when pool mode:
a) with skimmer closed / off position
b) with drain in closed/off position
c) with drain and skimmer open (obviously)
With those conditions the issue has to be between the pool side of the pool/spa jandy valve and the suction jandy valve, right?
Very little progress using the bucket of water trick. I also used press and seal to wrap the fitting areas of the jandy valves. The only time i thought i saw a reduction of air bubbles was pouring water over the handle and grease cap areas. Am i missing something?
