Homebrewale
- Apr 21, 2020
- 1,551
- Fiberglass
- Pentair iChlor 30
Correct. It's a choice, not a need.
But the overwhelming majority of folks who've tried 24/7 never went back.
You'll never wonder if you skimmed or filtered enough and FC will be topped off around the clock.
You're going to run half the day anyway. In the spring and fall the SWG needs less runtime but the skimming and filtering needs more. Adding 12 hours at 100something watts at low rpms may cost you $10 or $15 a month and you won't even know on the electric bill.
Let's do a calculation. Let's assume the electricity usage is higher at 200W per hour. 12 hours extra each day is 2400 Wh. If there are 30 days in a month, that is 72,000 Wh or 72 kWh. I don't know what the OP electricity cost is but mine is $0.11661 per kWh. It would cost me $8.40 per month extra to run 24 hours per day. What is the cost of the CalHypo the OP is using? What would be the cost of chlorine to do a SLAM if the pool gets algae? Running 24 hours per day is the cheaper option, even cheaper than your napkin estimate.
