I have a spot on my pool that has extremely stubborn algae. I've tried brushing it off with a brush using metal bristles. A solid 50 back/forth strokes didn't do that much sadly. In the past, I was able to brush the algea and it would basically 'dust' off into the pool and would be easy to dislodge from the wall. This is the first time that I'm facing such stubborn algae it simply doesn't respond to brushing. I'm shocking my pool hard and I know this will work from experience. However since the pool has been neglected for 1.5yr, I suspect that it never really fully died and got somehow stuck in the crevice or maybe behind a calcium buildup and although the pool thereafter appears clean, the fact that it's always the same spot that generates algae makes me wonder if there isn't something larger here. And every time it comes back, it's insanely stubborn. The brush is virtually useless.
Am I at the stage where algea is hiding in so many crevices that I'd need an acid wash to fully rid my pool of the stubborn algea?
